跳转到主内容
The Bose SoundLink Color is a Bluetooth speaker, designed as a more affordable and portable alternative to the SoundLink Mini.
aux in is broken ,how can it be fixed
aux in is broken ,how can it be fixed ? do i need some Accessories
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
@boseman how is it broken? Is the connector physically broken or what is going on with your Bose?
完成的
添加一条评论
1个答案
最有帮助的答案
@boseman take a look at this guide. Step 6 shows the port soldered onto the board. So it would not be easy. You could try and purchase a broken Bose SoundLink Color and harvest the port from it. Or you could possibly pigtail a separate input port (cable) to it. This will depend on your soldering skills etc. If you can, post some images of the damage (disassembled) with your question. For that use this guide. That would allow us to see what you see and possibly point out where to solder to.
iFixit图片
指南
在已经存在的问题里加入图片
难度:
非常容易
2 - 5 minutes
Bose SoundLink Color Speaker图片
指南
Bose SoundLink Color Speaker Replacement
难度:
困难
20 - 30 minutes
这个答案有帮助吗?
得分 2
2条评论:
I have uploaded several pictures of it.
Ccould you help me to see whether i can fix it by using the old aux and just fix it (not replace ),
完成的
@boseman Looks like the walls on the jack have actually cracked. so that would not be something that can be fixed but would require some sort of replacement.
完成的
添加一条评论
添加你的答案
Kyle 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 8
总计 715
