跳转到主内容
加入维修社区 - 创建账户
Bose SoundLink Color Speaker Replacement
你所需要的
    1. Bose SoundLink Color Speaker Replacement, Outer Casing: 步骤 1 中的图像 1,2 Bose SoundLink Color Speaker Replacement, Outer Casing: 步骤 1 中的图像 2,2
      • Four round, plastic plugs are located on the back of the device.
      • Using a metal spudger, carefully pry up the plastic covers.
      • The covers are all glued on, so be careful not to scar the casing when prying them off. If possible, use a spudger or plastic opening tool to remove them.
      添加评论
    2. Bose SoundLink Color Speaker Replacement: 步骤 2 中的图像 1,2 Bose SoundLink Color Speaker Replacement: 步骤 2 中的图像 2,2
      • Remove the four 1.8 cm-long T15 Torx Security screws from the outer case.
      • Some of these use T15 "Star" 5-point Torx security screws instead of the more common 6-point ones.
      添加评论
    3. Bose SoundLink Color Speaker Replacement: 步骤 3 中的图像 1,2 Bose SoundLink Color Speaker Replacement: 步骤 3 中的图像 2,2
      • Carefully open up the casing.
      • The top button pad may need to be re-glued upon installing the new casing.
      询问修复机器人
      添加评论
    1. Bose SoundLink Color Speaker Replacement, Speaker: 步骤 4 中的图像 1,2 Bose SoundLink Color Speaker Replacement, Speaker: 步骤 4 中的图像 2,2
      • Lift up the retaining flap on the button cable ZIF connector.
      • Pull the button cable straight out of the connector.
      • Remove the inner assembly.
      添加评论
    2. Bose SoundLink Color Speaker Replacement: 步骤 5 中的图像 1,1
      • The speakers are on the front of the inner assembly.
      • Using the Phillips head screwdriver, unscrew the four 1.3 cm screws holding the speaker that will be replaced.
      询问修复机器人
      添加评论
    3. Bose SoundLink Color Speaker Replacement: 步骤 6 中的图像 1,2 Bose SoundLink Color Speaker Replacement: 步骤 6 中的图像 2,2
      • Three screws hold the printed circuit board.
      • Using the Phillips head screwdriver, unscrew the three 1.2 cm screws.
      询问修复机器人
      添加评论
    4. Bose SoundLink Color Speaker Replacement: 步骤 7 中的图像 1,2 Bose SoundLink Color Speaker Replacement: 步骤 7 中的图像 2,2
      • Desolder each the three pins connecting the speaker to the motherboard.
      • Carefully lift the motherboard with a spudger to ensure that each pin desolders.
      • Work carefully. Prying too hard may cause damage to the board.
      添加评论
    5. Bose SoundLink Color Speaker Replacement: 步骤 8 中的图像 1,1
      • Push the speaker through the front of the inner assembly.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
21等其他人完成本指南。
13指南评论
Thanks for this tear down. Never thought that it looks like this on the inside. My battery is kind off aging, bought the unit 7 months ago. Local Bose dealer said battery cost half of this speaker. I hope there is a cheaper alternative.
vintiglao22 - 回复 分享
You can unsolder the battery and replace with a standard unprotected 18650 cell it literally costs 7$ for a high quality sony or panasonic or samsung cell. The protection and charging circuit is included in the speaker motherboard just make sure you resolder with the proper polarity.
swiftink - 回复 分享
Como ago para traducir cada
luis beltran - 回复 分享
Speaker looks like a 18650 lithium ion- from the pictures here.
DR Paquette - 回复 分享
Does anybody know where one could order a spare speaker for this device?
sebastiansebisilva - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 6
过去 7 天: 61
过去 30 天: 229
总计 36,376
