跳转到主内容
iPhone4S是第五代iPhone。网络制式为GSM/CDMA ,存储容量有8GB、16GB、32GB、64GB可选,机身颜色有黑色、白色可选。维修iPhone4S是容易的,需要耐心,用到的工具有螺丝刀、撬棒等。
2193 个问题 查看全部
iPhone 4S refuses to charge
so I found an iphone 4s in storage and wanted to get it working
I plugged it in…nothing….
I got it to work eventually but it only charged to 6%
Later it died, I haven't got it to charge since
It occasionally shows the apple logo, then shuts down immediately apon boot and refuses to charge
What is going on please help!!!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
@theandroidkid the very first thing you want to do is to change the battery. The charging issue as well as the shut-downs etc. can very well be related to that. Once replaced, re-evaluate. Until you’ve changed the battery anything else will just be a guess
iPhone4s 电池更换
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Bryn Trainor 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 24
