跳转到主内容
苹果 iPhone 5s 于2013年9月10日公布。该设备的维修与以前的型号相似,需要螺丝刀和撬棒。可使用GSM或CDMA / 16、32或64 GB。颜色有银色、金色和太空灰。
Why does my iPhone constantly vibrate when plugged in? No display.
So this was a phone given to me by a friend. The power button didn’t appear to work so I suggested a replacement. It did this wierd thing where it would only hold a charge to 2% when plugged in and switch itself off. So I replaced the volume flex and now there is no disaplay but when it is plugged into power, it just vibrates. It started as a contiuous vibration, but now it’s more like a phone call - intermittent. I had thought about changing the battery to address the charging issue, but I can’t seem to get my head around the vibrating situation. Any info would be helpful, thanks!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
This is a hated issue where if the battery gets over a certain % it kills itself. It can either be the battery, software, charger or blown cap or resistor. Try turning off battery percentage and turn it back on, try different software and finally change chargers. If all else fails take it to a repair shop as this can be a tricky subject
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Brandon Frost 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 59
