跳转到主内容
Hi, I am unable to power on
Unable to power on my laptop,even after battery removal
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
2条评论:
What happened before it wasn't turning on? did it power off suddenly or after the battery drained?
完成的
i had the same problem - i could not power on, and had difficulty powering off completely. the power button was flashing slowly along with the caps lock key - the screen was pulsating gently at the same rate. when the mains power was plugged in it would power down completely if i held the power button down, but would not power up.
any way - i loosened all the screws and took off the bottom to see what i could see - and that fixed it!! so i gave it a small clean and pressed one or two things in place in case it was a poor connection - it is now running again.
完成的
添加一条评论
1个答案
Hey Wow,
Are there any indicators when you plug in in to AC power?
Do any lights show up?
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
WoWsOmE ViN 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 15
总计 353
