跳转到主内容
加入维修社区 - 创建账户
Toshiba Equium P200-178 是一款 2000 年代中期发布、17.1 英寸的笔记本电脑,是热门的 Satellite P200 系列中主打经济实惠、面向商业用途的区域版本。它搭载了主频为 1.73 GHz 的入门级 Intel Pentium 双核处理器,并配有最大 2 GB 的 DDR2 RAM 系统内存配置。
Not POSTing or turning on
I was using an old Toshiba Equium laptop as a DVR for a security cameras. This weekend I was going to tidy up my Television area as it was very messy! I unplugged everything and when I got to the laptop it suddenly shut down (before I touched it). then once I came back to plug it back in I pressed the on button and nothing happens, I tried again and accidentally hit the internet button and it fired up! and after a few second the fans turned off and the lights turned off so I tried replacing the ram and that did nothing. after that I ran out of things to try, could people post suggestions!
in summary it only turns on when you press the internet button, once it comes on it shuts back off immediately!
hope you can help!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
2条评论
It turned on for about 30 mins after i left it for a week. but then it shut off and is doing the same thing
完成的
I think it might be the CMOS battery as it said something about that as turned it on. but i don't know why that will prevent it from booting
完成的
添加一条评论
3个答案
最有帮助的答案
Quite old laptop so try the following:
  • Unplug charger from laptop, take out the battery, press power button for 15-30 seconds, to dischage, and then only plug in the charger and press power button.
  • Does it work? Yes?
  • Then replace battery, from a reputable company.
  • O.K. so you have been just running it on the charger. Is the charger still good?
  • A system that old I would just replace the CMOS battery or even reflash the BIOS. And who knows, the BIOS could have gotten slightly corrupted during a power outage or the like. I have had many system doing strange things and it was slight corruption that was the cause. You never know until you try it.
这个答案有帮助吗?
得分 1
添加一条评论
your description isn’t specific enough to be certain, but it does sound like it may be a battery issue.
The questionable part is why it does anything when you hit the inet button. If the battery is dead, nothing should happen. There is also no indication in what you stated that it is a RAM issue.
这个答案有帮助吗?
得分 0
3条评论:
The battery is dead, so it had been operating for ages without one and operating off wall power. it makes no sound just boots up for 2 secs then turns off.
完成的
what if you remove the battery?
完成的
If you remove the main battery it does the same thing
完成的
添加一条评论
нет видиё карта
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Jeremy 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 16
总计 508
