跳转到主内容
首先 你得要准备一部iPad Air(1rd Gen)只支持Wi-Fi的机型 这里我们指的是A1474机型 它拥有64位的A7双核处理器并拥有16,32,64GB甚至是128GB的内存选择
Device not charging when off, but charges when completely off
So my iPad Air doesn’t charge at all when it’s on, and when I plug it into my computer, it shows the USB not recognized or malfunctioned. I’ve tried it on another computer, used different genuine lightning cables, same result.
However, when shutting off the iPad, it apparently starts to charge (according to the readings (Volts and Amps) on the Battery Activation board. I have updated it to the latest iOS but nothing has changed. So to summarize, it does not charge when the iPad is on, but does charge when completely off. What would be the problem in this instance? Thanks!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
If you used a particularly cheap cable from Amazon, eBay, Wish, AliExpress, or any other retailer that sells cheap cables, you might have damaged TriStar. What happens when you flip the cable’s orientation around? Does the same issue happen? For context, TriStar is a USB validating chip. Apple designed that chip to detect whether or not the accessories you’re connecting are certified, even from aftermarket manufacturers. The reason being is apple designed a special circuit board that is attached to the lightning connector that talks to TriStar. On this proprietary circuit board there’s built in surge protection. Apple sells this circuit board to third party manufacturers and cheap accessory manufacturers don’t have proper surge protection which results in damage to TriStar and can lead to the issue you’re experiencing. There’s a tool you can buy to test it yourself but they’re around $150 or call around your local repair shops and see if they have a TriStar tester.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Remy Stark 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 96
