跳转到主内容
加入维修社区 - 创建账户
50" Plasma TV by Sanyo released in 2007.
Why wont my tv turn on. No power it just turned off.
It just cut off and will not power back on.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 5
4条评论
More info please. How old is the TV? Any noises or smoke or anything that might help us know if something blew up and where?
完成的
TV is 3 years old. It didn't make.any noise it just powered off. I had a couple other peices of equipment power at the same outlet and they work fine.
完成的
There really isn't much more I can say. I was sitting here watching it and it just cut off like the power went off. No noise no smoke nothing. I have the back panel already off but I can't tell if any of the fuses are blown. Seems all the other problems ppl are having thiers will power on with no picture but mine doesn't power on at all now
完成的
Definitely check the power board for bad condensers. It looks like this model is somewhat plagued by those.
完成的
添加一条评论
1个答案
已选择的解决方案
Chris, I most certainly agree with Phillip Takahashi that we need more details to really help you out. Hope you are handy with TV repair, since this model seems to have its issues. Do a search on here and see if some of the old answers will help you getting started. Click on solutions and scroll through those. In the meantime, I attached the No Power flowchart for you so that you can see if it is one of those errors. I do have a feeling that you are looking at issues with the power board. Commonly the capacitors on this board go on the fritz :-) Of course make sure that all the fuses are okay and that you have nothing visible shortening out the board. You can download the Service Manual from here Hope this helps, good luck.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Chris 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 13
总计 16,741
