跳转到主内容
Repair information for the Samsung Chromebook Plus. Released in February of 2017. Model number: XE513C24.
How do you replace the hinge on Samsung Chromebook Plus V2?
It’s fairly easy to remove the display assembly, and then removing the trim piece across the bottom of the display reveals the hinges, but the hinge screws are obscured by the glass. Is it possible to remove and replace them?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
You're pretty much better off replacing the whole display assembly now, since the grade A OEM parts are not that expensive anymore. Also, it would be hard to find the hinge itself as a replacement.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Mike 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 15
总计 114
