跳转到主内容
加入维修社区 - 创建账户
Nintendo DSi 是 Nintendo DS 产品线的第三款迭代机型,于2008年底在日本市场发布。
My dsi doesn't work
My Dsi was fine but one day I turned it on and pressed a to go onto a game and it said " an error has occurred. please press and hold the power button to turn the system off. please refer to the operations manual for details." my brother said it's different than everybody else. please help me!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
3条评论:
We need to know more. Did you follow the instructions from the manual? What were those instructions? Does it turn on at all?
完成的
What firmware are you using and what card are you using? Did you have any recent updates? What does your brother see that makes him say "it's different than everybody else"?
完成的
Mine does the same but with everything including settings
完成的
添加一条评论
1个答案
Here is a preliminary suggestion until we can get more detail.
1) Check whether the Micro SD in FAT32 format.
2) Check whether the dsi pins are clean. Many problems are caused by dirty pins
3) Sometimes it takes some time to recognize the Micro SD. If the error occurs try restarting, wait for 5-10 seconds and then start the board
There is also the possibility that your DSi has Nintendo firmware which can block flashcards etc.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Saffron 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 5
总计 1,245
