跳转到主内容
2.4GHz, 2.7GHz, or 2.8GHz quad-core Intel Core i7 processor (Turbo Boost up to 3.8GHz) with 6MB shared L3 cache. Released February 2013.
Early 2013 MacBook 15" Retina display hinge replacement
Hi All,
I am trying to replace both broken hinges on my Early 2013 Macbook 15” Retina. I have all the necessary parts in hand and have separated the display from the body successfully. Now, however, I have hit a snag: I can find no disassembly instructions for removing and replacing what I believe must be the WiFi wire. Any links and/or tips? Thanks for any help!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Sorry we don’t have a guide, all we have is this MacBook Pro Retina Display Teardown for reference.
这个答案有帮助吗?
得分 1
15条评论:
Thanks! I only hope this doesn’t mean I have to tear the display apart to replace wires...
完成的
Yep! You do ;-{
The better direction is just replace the entire lid assembly 15" MacBook Pro Retina Display Assembly, Apple P/N 661-7171
完成的
Sadly, I fear you are correct. All for a 1/4" Retina connector that won't go through a lid hinge. Shame on Apple. And any display disassembly looks doomed to disaster. However, here's what I think I will do (less than optimal, but reasonable): I will try to untangle and keep the old Retina wire as well as the new replacement one. I might be able to adhere them adjacent to the laptop lid without cutting them. No more onboard camera, but everything else will work. If there only was such a thing as a male-to-male Retina plug adapter...
完成的
@dschind - As much as I would like to tell you that would work, it won't! The camera cable also carries a voltage and thermal sensor which if you disconnect will cause your systems SMC to throttle the CPU and ramp up the fan.
完成的
Thank you so much for your contribution! This has given rise to one other (maybe crazy) thought. What if I can succeed at prying apart the hinges themselves enough to swap new-for-old? Then I can leave the cabling untouched and functional. Very tricky at best, but...
完成的
显示更多的10条评论
添加一条评论
添加你的答案
dschind 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 9
总计 503
