跳转到主内容
加入维修社区 - 创建账户
Logitech G933 Artemis Spectrum 是一款支持有线和无线连接的游戏耳机。该耳机发布于 2016 年 10 月,可通过型号 981-000620 进行识别。
Sound Problem because of On/Off Dial
Hello,
I have the following problem with the headset:
The sound is sometimes very inconsistent. Example on a music track, I hear the music consistent but distorted, but the singing partly not and when it does as if it were coming from a distance.
However, if I now wiggle the on/off lever, it fixes the problems as long as it is in a certain position.
Does anyone know the problem and how to fix this?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 18
添加一条评论
4个答案
最有帮助的答案
Hi,
I had the same issue and I fixed it by cleaning the connection of the switch. If you look at my picture you’ll see the dirt causing the issue. I’ve also linked the video I followed. Hope this help.
https://www.youtube.com/watch?v=9r8KK3yn...
这个答案有帮助吗?
得分 12
5条评论:
What screwdriver do you use?
由完成的 分享
@Solomon Salzman I just fixed mine today, following that video.. i used the iFixit bit "J00"
由完成的 分享
I used this for my g935's worked like a charm. Just a heads up though those little flat pins on the actual switch aren't glued in and are tiny so use caution when cleaning. thanks for the video!
由完成的 分享
This is the Fix for this problem, done it multiple times.
由完成的 分享
You are Jesus Christ. Thanks. I was already thinking about changing headphones....
Today I found this article, did it, and solved!!! 😜
由完成的 分享
添加一条评论
I can confirm this fix works.
I used fine tweezers to remove the switch cover, then used isopropyl alcohol, a cotton tip and a pointy plastic spudger to scratch off the dirt.
While in there, I removed the battery bay and dongle bay to add PTFE grease to the tilt hinges; this eliminated 80% of the plastic creaking noises
Before>>>
After>>>
这个答案有帮助吗?
得分 5
添加一条评论
Same issue. Cleaned the switch, sprayed some dry ptfe lube on, bent the metal strip so it tensions down a bit more on the slider and wham bam it works like a charm.
No more smacking the thing like a mad man XD.
这个答案有帮助吗?
得分 0
添加一条评论
I used the guide from @alexandrec11706 but messed up and the power switch went flying across my desk because of carelessness. One of the 4 tiny metal contact points was lost. So I ended up soldering the contact points for the switch so that it is always turned on. PS: Remember to permanently remove the plastic switch if you go the solder route so it does not short. I've included a schematic of the contact points. Green Are the pegs you want to solder to keep the device in a permanent on state. Red is the off state.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Dominik Traise 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 13
过去 30 天: 84
总计 6,877
