跳转到主内容
2.4GHz, 2.7GHz, or 2.8GHz quad-core Intel Core i7 processor (Turbo Boost up to 3.8GHz) with 6MB shared L3 cache. Released February 2013.
20 个问题 查看全部
Searching for right-hand display hinge.
Hi:
I am searching for a source that will sell me a right-hand (WiFi) display hinge. Finding the left-hand (display) is easy, but both my hinges are broken. Thanks in advance for your suggestions!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Here’s the part: 13” MacBook Pro Right Hinge - Antenna/iSight cable, Apple P/N 818-2781
这个答案有帮助吗?
得分 2
7条评论:
Thanks! I live in the US, and so a UK source isn't ideal, but is much closer (and The Bookyard is probably more reliable a seller) than an eBay dealer in China.
完成的
@dschind - I find them better than what I have dealt with in China. See what you can find leveraging the P/N info.
完成的
Yes. The P/N info alone is very helpful. Appreciate it!
完成的
BTW? I got myself the part but ended up not using it. Why? To install it, I would have to destroy the display one of its cables has to plug attach to. LOL.
完成的
As you had asked for the hinge alone I figured you had reviewed what it would take to replace,
Your only other solution is replacing the complete display assembly. Now the fun begins! Try finding one, Retina MacBook Pro 13" Complete Display (12/E13), Apple P/N 661-7014 They are a rare find these days, and the quality can be poor (suffering Staingate).
Review this MacBook Pro Retina Display Teardown to get an idea what's involved. If the hinge and/or the cables running through it has failed I would take the gamble fixing it Vs replacing.
完成的
显示更多的2条评论
添加一条评论
添加你的答案
dschind 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 2
总计 65
