跳转到主内容
A tablet developed by HP in 2011 running the webOS platform. Boasts a 9.7" display, and is available in 16 or 32 GB. Repair is straightforward, but requires time and persistence.
56 个问题 查看全部
问题已关闭
Is LCD Glass Cover Replacement Possible
I was thinking about buying a HP touchpad with a damaged glass cover ( the plastic or glass cover for the LCD screen)...... the LCD screen is undamaged and the touchpad works fine, just has a fairly nasty crack in the glass or plastic casing that covers the LCD screen.......
i have not been able to find replacement parts for this product anywhere..... i know it is discontinued, I thought i would ask anyway or is the only way to get parts for this threw HP direct if they even have them?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
http://www.ebay.co.uk/itm/HP-TouchPad-16... one with a good screen but otherwise broken..save yourself $350!!
完成的
添加一条评论
2个答案
已选择的解决方案
Brian take a look at these and see if it helps. Parts are available here http://www.portatronics.com/index.php?ca... and here are the guides for the repair HP TouchPad
这个答案有帮助吗?
得分 2
1条评论:
Thank you for the info. It would seem parts are pretty expensive for this device.
完成的
添加一条评论
Just bought one at: http://www.repairsuniverse.com/hp-touchp...
这个答案有帮助吗?
得分 0
添加一条评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 1
总计 5,502
