跳转到主内容
Intermittent shutdown with flashing RED led 9 times.
Sony Bravia KD-65X9000B occasionally shuts down with main LED flashing 9 times ( then 3 seconds and repeat).
Sometmes it will restart with remote but mostly needs complete power removal for 15 minutes for restart.
Any ideas what 9 flashes means with this Sony ?
Thanks!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
Facing the same issue
完成的
添加一条评论
2个答案
已选择的解决方案
Hi @aksal60 ,
According to the service manual a 9 blink error code indicates a problem with the TU board (tuner board). The manual is for both the 55” and the 65” models
Here’s a poor image of the blink error code chart and the location of the TU board.
(click on image to enlarge for better viewing)
The service manual can be viewed for free online but it is low resolution, so some sections are hard to make out. Also there are no schematics in the manual.
To download the manual you have to pay for it. To move through the manual you have to select the appropriate page number below the document and click on Go. There are 127 pages in the manual.
Page 71 of the manual shows the location of all the screws that hold the back cover.
Hopefully a start.
这个答案有帮助吗?
得分 3
3条评论:
Nice one - thankyou. Was thinking a PS fault but maybe not so now.
Thanks again.
完成的
Has anyone come up with a fix or solution for this problem - I have the same problem.
完成的
I am also facing the same problem with Sony 49’’
完成的
添加一条评论
I have the same problem on a KD-70X8500B
This model has a seprate tuner board.
I removed the tuner board and powered on still get same problem.
Can sony run without the tuner board if there seprate from the logic board?
I wish there was a list of things to check if you get the 9 blinks? It says what the possible issues could be, power board?
Anyone know the answers above ?
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Daniel Fleming 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 22
过去 30 天: 81
总计 4,071
