跳转到主内容
华为子品牌荣耀的修理
20 个问题 查看全部
honor 20pro camera does not work
beautiful day gentlemen, I come to you for advice.  honor 20 pro after falling to the floor camera application does not work.  factory setting done but did not help.
Text-“The camera now doesn't work.  you may need to close any other camera applications you are running.”
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Hi,
The camera module may have been damaged by the fall or perhaps it is only a loose cable connection from the module to the board.
Here’s a video that shows how to replace the camera module in the phone. You can also use it to check if the module’s flex cables connection are OK or not.
Replacement camera modules (supplier example only, to show what the part may cost) are available online. Just search for Huawei P20 Pro camera module to get results for suppliers that suit you best.
这个答案有帮助吗?
得分 1
3条评论:
if the camera module was damaged, the application would start and switch to selfie camera, right?
完成的
@hipisak
I don't know maybe not as you haven't mentioned that it does or not.
maybe the application needs all the cameras to work or at least be "seen" by the software before the app fully opens. That would be the most logical way to do it.
The camera software may check if there is communication between all the cameras and the systemboard and if OK then open the app for the user to be able to use the cameras
完成的
thank you for the advice.
完成的
添加一条评论
添加你的答案
hipisak 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 5
总计 127
