跳转到主内容
加入维修社区 - 创建账户
13英寸铝合金一体成型机身,2.0 或 2.4 GHz Core 2 Duo 处理器。
MacBook Pro not turning on
Have an old MacBook Pro 13-inch mid-2008/early-2009 (the one with the two-part bottom).
It’s not turning on, the charger turns orange, but trying to reset the SMC doesn’t appear to work, as I don’t get the confirmation blink turning to green.
What do: This is an ‘as is’ computer I bought, so don’t have a lot of history on it except the owner claimed it worked when he last used it. Was stripped of RAM and HDD, so I put them in.
No beeps when trying to start. Nothing! Not powering on at all, but charger indicator is Orange.
Edit: Could this be the problem?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
7条评论
one more detail, the three long screws at the back are missing, and instead are the small screws. Unsure if I can replace with 'newer' 14mm screws from the 2009+ models of the same make.
完成的
With the computer open and sitting on a table in from of you, look at the left hand side of the top case (the component which houses the keyboard and trackpad). You should see a small gray button with about 8 perforated holes next to it. Press that small gray button. Do the perforated holes light up? If so, how many lights does it show? (This indicates the charge of the battery and can help us determine whether or not the battery is completely drained).
完成的
I'll try later, but it's been laying bare for several years, so I'm pretty sure the battery is drained. It should still turn on though, yes?
完成的
There was no 13" model with a split bottom cover (able to replace the battery without taking the bottom off) I've corrected the model info to the 15" model which does.
完成的
I'm sorry, but I'm actually looking at a 13-inch right in front of me that has the split bottom..
完成的
显示更多的2条评论
添加一条评论
3个答案
最有帮助的答案
On the Left side is your systems battery checker
With the charger disconnected what happens when you press the button? Do you see the small 10 LED’s? Are only a few lit? Are they blinking?
这个答案有帮助吗?
得分 2
7条评论:
I'll have to check later. Thanks!
完成的
Nothing. No light light up when I push that button.
完成的
Time to replace the battery! MacBook Unibody (A1278) Battery. You also may need a new MacBook Unibody (A1278) Battery Connector as the contacts often failed on them.
完成的
Right. Could I get the machine to start if I completely took out the battery, you think?
完成的
Ok, so, found the culprit with the battery. There was a slightly loose connector, (I think that was the DC one), I plugged it all in, and suddenly the battery blinks when pushing that side one.
However, the machine still does not start. That also goes for when not having battery in.
Starting to wonder if the keyboard and power button simply isn't properly attached. Which connector is that?
All other connectors seem to be fast. Gut feel definitely is that it's not registering my keyboard or power button push at all
完成的
显示更多的2条评论
添加一条评论
To bypass the keyboard and attempt a spontaneous reboot, disconnect the battery and mag-safe. Press and hold the power button for 10 seconds. Reconnect the battery and then then mag-safe and if all is well and you have some charge in the battery, it should spontaneously reboot.
这个答案有帮助吗?
得分 2
2条评论:
Will try. Going to post a picture in edit of a cable I suspect may be the problem in a sec. Input would be appreciated.
完成的
No on the spontaneous reboot. Is it possible the power-button is not connected?
完成的
添加一条评论
get some isopropyl alcohol and make sure the board is clean - use a magnifying lense to check all over
这个答案有帮助吗?
得分 0
1条评论:
I doubt that will matter here. The first step is to see if the system spontaneously starts up after doing a hard reset as Mayer wrote. If that worked the battery needs to be charged more likely replaced.
If the system won't start that's a logic board issue which might be a simple blown capacitor but it will take some effort to trace out the power rails to discover what failed and then getting the part reviewing the schematics and board view drawings.
完成的
添加一条评论
添加你的答案
Opti 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 30
总计 405
