跳转到主内容
加入维修社区 - 创建账户
The Nexus S is a smartphone co-developed by Google and Samsung was the first smartphone to use the Android 2.3 "Gingerbread" operating system.
Left vertical Area unresponsive
I bought a uses nexus S and found that it had an unresponsive to touch area of the screen. This area is a 1cm large rectangle.
Which parts should i replace to get back a fully working screen?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
已选择的解决方案
Montasser Ben Gadri, usually when the digitizer (touch) is unresponsible at a certain area of your screen, it is the digitizer that needs to be replaced.
这个答案有帮助吗?
得分 1
4条评论:
Thank you very much for your answer. Is it easily replacable? Where do i find the cheapest place for nexus s digitizers?
完成的
Thank you for accepting my answer. Sorry, nothing is ever really easy, but it is not a bad job. Check on the teardown Nexus S Teardown it does give you a good idea what's involved. You can also check om here http://www.repairsuniverse.com/samsung-g... As for the cheapest place, it really depends on your geographical location.I tried Google and average price ~$120....Hope this helps.The reason for that is cause the Digitizer and the LCD are a lot easier to change as one unit....
完成的
http://www.ebay.co.uk/itm/New-OEM-LCD-Sc... $80... but it's from china, so you'll have a wait on delivery.
完成的
Thank you for your great help.
完成的
添加一条评论
添加你的答案
Montasser Ben Gadri 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 10
总计 763
