跳转到主内容
Galaxy tablet lite variation released in January 2014. The Samsung Galaxy Tab 3 Lite is a lightweight and easy-to-use tablet.
20 个问题 查看全部
In factory reset, how do I get out?
I want to get out of the factory reset
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
I guess you’re using the recovery mode to reset the device and you want to exit that screen. Simply use the volume up & down keys to navigate to “reboot phone” and press the power button once to select it.
Here is the complete steps to factory reset and exit recovery mode.
  1. If your phone is on, power it off.
  2. Hold down the Power and Volume up buttons simultaneously. You should see the Samsung logo followed by an "Installing system update" screen.
  3. After a few seconds, you should see a "No command" message flashing on the screen. Wait 10 to 15 seconds at this screen and the device will enter recovery mode.
  4. Use the Volume buttons to scroll through the menu and the power button to make a selection.
  5. Highlight Wipe data/factory reset.
  6. Press the Power button to select.
  7. Highlight and select Yes to confirm the reset.
  8. Once the reset is complete, you will be bounced back to the same recovery mode menu. Press the Power button to select Reboot system now.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Lloyr 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 2
总计 72
