跳转到主内容
3.3" tall Siri-powered smart speaker, made by Apple Inc. Released November 16, 2020 in Space Gray and White. Was later updated with new colors such as Blue, Orange, and Yellow. Model number A2374.
4 个问题 查看全部
Splicing a new USB-C cable on HomePod Mini
Does anyone have the pinout color code for the attached USB-C cable? Within an hour of unboxing my HomePod Mini, my parent’s dog chewed the connector off the cable. As the official repair cost to repair is nearly the cost of a new device, I’m going to attempt to splice a new cable onto it. Anyone who has done a teardown or just taken it apart, would you be able to help me out?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
4条评论
The official Apple cost for repairing the cable is only 29$.
完成的
@tassilomoedl 29$ (Groceries for a day) saved if you do it yourself.
完成的
@oldturkey03 Yes, but the OP said it costs almost as much as a new HomePod, and that‘s not correct.
完成的
@tassilomoedl you are right, it is not. However, repairing the cable still saves the $29 you mentioned :-)
完成的
添加一条评论
1个答案
已选择的解决方案
Hi @alexdavila ,
USB-C, as with all USB types, are wired to a standard, so the wiring will be the same for each type of USB connection.
The difficulty with USB-C, as opposed to USB 2.0 say, is that there are more wires and that there are wires having the same colours but they are used for different functions and accidentally connecting them incorrectly would cause problems.
You would need to identify the wires at one end of the cable and ensure that the wires were correctly terminated at the other end.
Here’s an image showing the pinout for a USB-C socket and plug which may help.
Here’s a link to the ifixit HomePod Mini Disassembly guide as well
(click on image to enlarge for better viewing)
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Alex Davila 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 17
过去 30 天: 100
总计 4,315
