跳转到主内容
A business-class notebook with a 13.3" touchscreen display.
20 个问题 查看全部
My HP 840 turns on but after 1-2 seconds turns off.
My HP 840 turns on with the HP logo and Bios but after 1-2 seconds turns off.
Not reacting on any buttons combinations. Turns on only if I connect the power adapter.
Tried to change the battery but not helped.
Please help.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
9条评论
So it works if the battery is disconnected and just the power adapter connected, is that correct?
完成的
@aactech No, it not.
完成的
@Ilya Liberman
So it is probably a mother board issue. Something is overheating quite quickly. Here is the url for the HP service manual:
https://support.hp.com/nz-en/product/hp-...
One other thing. Have you tried resetting the BIOS?
HP Elitebook 840 G1 Motherboard Replacement
Unplug the charger and disconnect main battery.
Look at Step 2. The CMOS battery is encased in yellow. Just disconnect its connector by sliding it up and off. Press your power button for about 15 seconds to discharge any power in the system.
Reconnect the CMOS "coin" battery, plug in charger and see if it turns and stays on.
Let us know how it goes.
完成的
@aactech I did a CMOS reset but it not helped me.
完成的
@Ilya Liberman
Always disconnect power and remove the battery before doing anything inside. Next I would take out, one at a time, the hard drive and Wi-Fi card, to see if they are defective and causing the shutdown problem. If that doesn't fix your problem then try removing the RAM and reinserting. If two RAM modules try one and then the other.
完成的
显示更多的4条评论
添加一条评论
3个答案
已选择的解决方案
It could be the battery or the motherboard of your laptop. Remove the battery then plug in just the charger and turn it on see if it will replicate the problem. If it turns on that means it's the battery. Also check if it's your HDD to test if it's your HDD.
- Remove the HDD off the laptop then turn it on.
- You'll get an error message saying boot device is missing or something and that's normal
- See if it will turn off again without the HDD, if it turns off again that means it's the motherboard.
Replace a 4450 mAh battery compatible with HP Model CM03. Part #716723-271, 717376-001, CM03, CM03XL, CO06, CO06XL, E7U24AA, HSTNN-DB4Q, HSTNN-DB4R, HSTNN-IB4R. 48 Watt Hours (Wh). 11.1 Volts (V).图片
产品
HP CM03 Laptop Battery
$34.99
这个答案有帮助吗?
得分 1
添加一条评论
Either the laptop have short circuit problem or bios problem need flashing
这个答案有帮助吗?
得分 1
添加一条评论
swapped in another ram stick or change ram slots computer booted.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Ilya Liberman 将永远感激不已
浏览统计数据:
过去 24 小时: 6
过去 7 天: 46
过去 30 天: 111
总计 11,435
