timing chain position on sprokets
I have a 2001 Pontiac Grand Am 2.4L 4 cyln. Where to set the timing chain if its out of place?
Here is a diagram the shows you how it is all setup. Just wondering if you have ever done this kind of work before. It is very involved and not quite as easy...
这个答案有帮助吗?
+ And if you get wrong you could destroy the engine. I usually change the water pump at the same time--you have to remove it to get to the timing chain. And double check the sprockets.
may I have that diagram too. thank you
@draccocain Carson, Dom, Below is the 2.4L 4 cyln. timing diagram. Good luck.
这个答案有帮助吗?
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 7
总计 3,495
