跳转到主内容
加入维修社区 - 创建账户
2011 年推出;序列号为 1d16dx。
multiple software problems with my computer
the exact correct model of the laptop im having problems with is an hp pavillion g6-2365ea for whatever reason there was no option to select that model
anyway the problem is: i am unable to download anything from the internet, when i do, i get a pop up that says: a device attached to the system is not functioning, so after doing some research into this, this error has something to do with connectiong iphones to windows 10, HOWEVER this error comes up even with nothing attached and it prevents me from downloading anything whatsoever. i also cannot open command prompt as administrator or use the search bar besides the windows icon…i also cant use my hirens boot disc with this machine either as it ignores it and goes straight to normal boot even when i select boot from cd as the top priority in the bios, i also reset the whole thing once, wiped everything but the same problems remained.
Update (12/30/2020)
ok so an update: i have tried running the system test from the bios or whichever thing it is by pressing esc repeatedly as its starting up, which brings me to the following menu where i have these options:
f1 system information
f2 system diagnostics
f9 boot device options
f10 bios setup
f11 system recovery
enter - continue setup
so then i go into the system diagnostics which brings me to this:
memory test
hard drive check
language
exit
so i run the memory test, that takes about 10 minutes, it comes up: passed
i run the hard drive test: the SMART check comes up as passed pretty quickly then comes the long DST which takes close to 4 hours it too comes up: passed and those are the only options i seem to have for testing any sort of hardware, i did indeed manage to eventually get the hirens boot disc to boot by turning off uefi and turning on legacy and going through the advaced start options but it lies and says its not possible the first time but succeeds the second time, i load up the mini xp and play around with some of the programs there such as the various anti malware/anti virus applications but im honestly not sure if theres anything useful at all on the disc
it seems that i can indeed finally access the device manager and msconfig in safe mode which i do and i find that the following things have exclamation marks beside them/need drivers or whatever:
microphone high definition audio device
monitors: generic pnp device
other device: unknown device
software devices: microsoft gs wavetable synth
sound, video and game controllers: amd high definintion audio device
system devices: microsoft hyper-v virtualisation infrastructure manager
and thats it. so i disabled all of the problem ones and tried rebooting it into normal mode, still the whole pop up thing and not being able to do much so i go back into safe mode this time not just disabling but also uninstalling a couple of them, so i pick the unknown device and the microphone just as an extra test, and i find still the same problems but not only that, when i go back in safe, i find that both the unknown device and the microphone have reinstalled themselves and are back to their exclamation mark state with the rest still being disabled…how is that possible?
i can run virus scans with windows defender or whatever it is just fine in normal mode and everything comes up clean but when i try to go through the same process in safe mode i get: windows security, security at a glance see whats up with the health of your device and take any actions needed….and thats it. the rest of that screen which should be full of content is just a blank white and when you click the 3 lines under the back arrow a side menu pops out, it too is blank white theres also the settings cog which when clicked comes up normal but there doesnt seem to be anything helpful there
one funny thing is: i have had absolutely no problems ever downloading firefox browser and using it either inside or outside of safe mode.
i have also downloaded the following things but cannot get them to run inside or outside of safe mode:
HPSupportSolutionsFramework-12.19.48.1 (to try and get new drivers downloaded)
sp77491 (the bios update)
bitdefender_online - some antivirus/antimalware
so not really sure where to go next with all of this, apart from knowing about the final solution of getting an ssd and installing linux on it and just ripping out the hardrive if all else fails
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
Whoops sorry lads meant to add this: I’ve updated my original post with the steps I took based on the suggestions you both gave and the results I got, thanks
由完成的
添加一条评论
1个答案
已选择的解决方案
We need to narrow down the cause of the problem. Below is a start to doing this.
Go into Device Manager by pressing the Windows Logo + X key combination on the keyboard and, from the list, click to select Device Manager.
Look for a yellow triangle containing an exclamation point over a device’s icon which indicates devices that aren’t working properly — possibly because of problems with their drivers.
This site may help:
https://support.hp.com/gb-en/drivers/sel...
Update the BIOS, if not already updated.
Update (01/01/2021)
I am 95% sure this all just a driver issue. The problems happen when they get corrupted and even after uninstalling there is still debris left.
From my experience, and needless to say I’m not perfect, the below choices are what have worked for me on many, many different systems of all ages. It still amazes me how rarely I have found actual hardware failures in over 35 years of experience.
Before I go on hirens boot disc is no comparisome to Sergei’s disk. Download it and with Rufus set it to boot on a USB flash drive. It does everything:
https://www.majorgeeks.com/files/details...
What I do, and I have done it many times is uninstall the drivers and then run programs like Ccleaner, Advanced System Care , etc. and DDU (Display Driver Uninstaller) for video card drivers:
Download, manually, the HP drivers from the HP support site into an HP driver folder. I always rename them for easy reference:
Install the HP drivers. Note: Sometimes running driver installers for ealier OS’s in Compatibility Mode helps
When done Reboot and run Driver Booster for the latest
Once I’ve done all this it is either fixed or just needs a little tinkering.
Sergei’s boots into W10 PE and finds drivers, generally automatically so then you can easily tell if all is basically working. Some of these driver issues can be buried kind of deep into the Windows OS.
P.S.
@jayeff and I are very stubborn and don’t give up easily.
这个答案有帮助吗?
得分 1
8条评论:
hi mike, when I try to do just that I get that bloody pop up again: "a device attached to the system is not functioning" and that just shuts me down from going further also I am unable to download anything from the internet whatsoever because of the same pop up that includes bios updates...apparently my current bios is: inside f.26 21/02/2013
由完成的
@weemawn
hirens boot disc won't work if secure boot is on.
Latest HP BIOS for your model that I could find is " F.2A Rev.A Sep 19, 2016" which is newer than F.26
(by the way it is spelt "Insyde")
Have you run System Test?
* Hold the power button for at least five seconds to turn off the computer.
* Turn on the computer and immediately press Esc repeatedly, about once every second. When the menu appears, press the F2 key.
* On the main menu, click System Tests.
* The System Tests menu displays. Run the Fast Test
Fast Test:
Battery Check
Processor Check
Wireless Module Check
System board Check
Hard drive SMART Check
Hard drive short DST Check
Memory Quick Check
Hard Drive Optimized DST Check
Video Memory Check
由完成的
@weemawn
Does the pop up occur if you start in safe mode?
If possible perform a safe boot scan either using Microsoft Defender (if this is your AV) or your 3rd party AV program.
If Win 10 and Microsoft Defender go to Settings > Update and Security > Windows Security > Open Windows security > Virus and Threat Protection > Scan Options > Microsoft Defender offline scan > scan now
由完成的
ok so ive tried to download that sergeis boot program you mentioned, which downloaded fine but its a .rar file so it will not show up in the rufus program (which i also downloaded) so then i researched how to convert a .rar to a bootable .iso and i downloaded the following programs: AnyToIso, express zip file compression, peazip, UltraISO, WinISO, Free ISO Creator, and ImgBurn i tried converting to an iso with all of those programs that i could (about 2 of them hit me with a paywall because of size limitations) i created various isos of it but non of them were bootable apparently for example when i try in rufus it says: this image is either non-bootable, or it uses a boot or compression method that is not supported by rufus and just for good measure i downloaded another program called balena etcher and when i try the same thing there it says: it looks like this is not a bootable image. the image does not appear to contain a partition table, and might not be recognized or bootable by your device
由完成的
显示更多的3条评论
添加一条评论
添加你的答案
weemawn 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 19
总计 1,094
