跳转到主内容
加入维修社区 - 创建账户
Fujifilm 于 2012 年 3 月发布的数码相机。型号为 HS30EXR。
How could I replace the triPod mounting hole?
The tripod mounting hole or tripod thread, has cracked in the camera and isn't very usable anymore. It cracked probably due to the fact it was plastic, is there any way i could add a new one/replace the damaged one?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
You could try putting in a new threaded insert like this one: https://www.amazon.com/1-4-20-Threaded-I...
这个答案有帮助吗?
得分 0
添加一条评论
That's a good solution that I'd consider, but how do I fix one of these into the camera? Do I need to remove the old tripod socket? Keeping in mind, it's plastic.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Piotrix 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 3
过去 30 天: 18
总计 558
