跳转到主内容
加入维修社区 - 创建账户
Released February 2018. Dell Inspiron 14-5482 features a 14.0" HD screen and Intel i7 core.
Charger needs to be put in a few times or rotated a bit to work.
Charger needs to be put in a few times or rotated a bit to work. Any idea why this may occur or how to fix it? Nothing appears wrong with the charger or port, but there is obviously an issue somewhere.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
Start with a new GENUINE power adapter and see if that resolves the issue first - a lot of the time, it’s just a bad charger. If that doesn’t fix it, you’ll need to replace the power jack.
On many of these newer Insprion models, the procedure to change the power jack is easy enough if you’re comfortable inside a computer, you can do it yourself. You can find the part here, and the service manual here.
Just a few years ago before Haswell, it was a crapshoot - some were easy, others were okay and some were awful. The new ones are a 15-20 minute job for anyone who knows what they’re doing, while they could be a genuine nightmare on many of the older ones - even IF you know how.
这个答案有帮助吗?
得分 3
添加一条评论
Clean the connectors using a pure alcohol and a Q-Tip.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
TYLER GOODWIN 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 348
