跳转到主内容
Audio Works But No Picture
Title says it all. When turning the tv on, the audio works but video does not. Have tried unplugging and plugging hdmi cable, swapping out for a different hdmi cable, and have tried unplugging and plugging the coaxial for the cable box, nothing works.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
Hi @tamrielbound ,
Can you view the TV menu screens OK?
Have you tried a different signal source, e.g. a dvd player and checked that it works OK when using it?
完成的
添加一条评论
3个答案
最有帮助的答案
Hi @tamrielbound ,
Can you view the TV menu screens OK, you didn’t say?
If you can’t see an image when trying either of the above, with the TV on and audio heard, shine a torch at an angle close to the screen and check for any images. They will be very faint if they are there so trying this in a darkened room may help to see them if they are there.
If you can see images then there is a backlight problem with the TV
这个答案有帮助吗?
得分 1
1条评论:
I can not see any images such as the menu screens. I tried several different hdmi cords, I tried a DVD player and a blu ray player. The backlight is working, you can see it go on and off with the tv. The backlight also flashes when I hit the Netflix button on the remote.
完成的
添加一条评论
LG sets made in 2018-2019 with BOE panels (including but not limited to European markets) are at a high risk of developing a fault with the screen panel/LCD module. The screen appears black, but the backlight behind is on - the 'OFF' state of LCD screens is black (blocks the backlight).
Mainboards of these sets have two versions: ones with two wider #1 and #2 LVDS connectors (68 pins each, for BOE panels) or two a little shorter LVDS connectors (60 pins, for LGD panels).
这个答案有帮助吗?
得分 1
添加一条评论
Describe tv model and to where you are connecting the cables.
这个答案有帮助吗?
得分 0
2条评论:
TV is the LG 43UK6300PUE and the hdmi cable is connected from the cable box to the tv.
完成的
And the cable box, is it connected to the dish? Then, you call the cable provider to set it at your place.
完成的
添加一条评论
添加你的答案
Charles Jackson 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 253
