跳转到主内容
华硕所制造的塔式台式机和一体机的维修和支持指南。
VGA No Signal when Windows XP logo Appears
Hello guys ,I hope you are doing well! So I am trying to boot up an old pc (from 2006 to be exact) using a Samsung HDD with Windows XP installed. I have selected it to be the first one in boot priority. When it's booting its asking me which mode I want to enter (safe or normal).
Whatever I select , it tries to boot ( showing me the Windows XP logo) and immediately stops and a message saying VGA NO SIGNAL Appears.
Any ideas would be greatly appreciated :)
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
Hi
What is the make and model number of the PC or the motherboard if it is a custom build?
Was the HDD with Win XP already installed, taken from another computer?
If so you will have troubles making it start when connected to a different motherboard as the hardware will be different and therefore the wrong drivers will be already installed in the OS.
This link may be of some help
这个答案有帮助吗?
得分 2
2条评论:
So this is the machine : https://www.manualslib.com/manual/10347/...
And Yes I am using an external HDD (with the OS) from another PC.
完成的
Hi @GO4GAME
I know nothing about servers but looking at this link the OS may have to be newly installed on a HDD in the server and not be an existing installation from another PC but i may be wrong about that.
Also it appears that even then there may be problems. Maybe try a Linux install as suggested in the link
Sorry I can't help more with this
完成的
添加一条评论
Unplug the VGA, then Wait for a couple of minutes, and then reconnect the VGA cable to your computer and monitor . Plug the Power cable back to your computer and monitor. Turn on . Try using an external monitor.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
GO4GAME 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 220
