Why will my MacBook not take more than 250GB Hdd?
Hello my mac book core 2 duo will not take more than 250GB of hard drive. i have tried 320GB, 500GB and 650GB and it won't work. it always get stuck at this point. it will not format when i format in OS it will format with Journaled with any problem and when i insert in back into the laptop to install it will give an error message saying the Os could not be install because the was no software to be install something like that. when i try to format with disk utility during installation it will give this error code saying ( Disk Erase failed with the error: input/output). but when i insert a 250GB everything goes smoothly without any error. have some one had this problem before? can some one help me out here?
4条评论
You've asked questions on Powerbook G4s and Unibodies, is this a different unit, all your machine seem to have the same type of problem: Why is MacBook Pro stuck in Apple logo with a spinning wheel?
由 mayer 完成的
What operating system are you trying to install? What are the last 3 characters of your serial number?
由 ABCellars 完成的
i don't have only one machine. i am trying to install Mac OS x 10.6.3
由 Julius Nfor 完成的
Have you considered it may be the data cable? are you buying the right HDD
由 Paul 完成的
