跳转到主内容
Released February 2012, identified by model number BP220.
9 个问题 查看全部
dv582h movie format help
I got an LG dv582h from a garage sale and I came home discovering it has a broken disc drive, so I’m trying to load movies onto a USB flash drive, but I can’t figure out the dumb formatting of it, I tried using the divx converter program on my laptop but every time i try the program just closes, even if I reinstall the program, the only movie I got working is San Andreas (avi file) yet all my other files no matter if they are avi or mp4 or whatever I can’t get it to work, and the LG website doesn’t give me ALL of the video info that works (like fps, resolution etcetera,) may I ask for the full info so I know what to change in all my movies
if you want to try converting it yourself i’d be happy to send you the files.
please help me out as this is literately driving me insane to the point where i’m about to put a hammer through it if i don’t make any progress
Thanks!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Hi @theandroidkid ,
It may be better to find out why the DivX program closes in the computer first.
According to the user manual:
USB operation
Music files (MP3/WMA), photo files (JPEG) and DivX files can be played.
This unit is not supported when the total number of files is more than 600.
Bit rate: within 8 to 320 kbps (MP3), within 32 to 192 kbps (WMA),less than 4 Mbps (DivX file)
The USB function of this unit does not support all kinds of USB devices.
DivX file requirement
DivX file compatibility with this player is limited as follows:
Available resolution size: 720 x 576 (W x H) pixel.
The file names of DivX and subtitle are limited to 45 characters.
DivX file extensions: “.avi”, “.mpg”, “.mpeg”
Playable DivX subtitle: SubRip (.srt / .txt), SAMI (.smi), SubStation Alpha (.ssa/.txt), MicroDVD (.sub/.txt), SubViewer 2.0 (.sub/.txt),TMPlayer (.txt), DVD Subtitle System (.txt)
Playable Codec format: “DIVX3.xx”, “DIVX4.xx”, “DIVX5.xx”, “MP43”, “3IVX”
Only the playback function is supported with DivX 6.0 in the unit.
Playable Audio format: “Dolby Digital”, “DTS”, “PCM”, “MP3”, “WMA”
Sampling frequency: within 8 to 48 kHz (MP3), within 32 to 48 kHz (WMA)
CD-R/RW, DVD±R/RW Format: ISO 9660
Maximum Files/Folders: Less than 600 (total number of files and folder
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Bryn Trainor 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 131
