Blank Screen, Caps lock light blinks 3 fast 2 slow. Need help..?
I have a HP pavilion laptop model: 14- ce0505sa. Was working perfectly. I just bought it a year back. The problem started when Microsoft sent the update. It was booting up frequently and then after a few days when I tried to reinstall windows and clicked restart it went of..and frm then the black screen and capslock light beeps. I thought it's the ram but it works on someone else's laptop. Open to suggestions. Would appreciate it if someone could help me out in this. Cheers
2条评论
Hey
In my case laptop turn on, fan working but no display shown on screen. Only caps lock keep blinking. Tried to change rams, 15 to 20 second press power button after discharge the battery but no luck. Any one has been go through same situation. Once display come then can do something about bios. Tried external hdmi thought screen issue but no luck.
由 Sidra Imran 完成的
Seeing this on multiple HP machines - BIOS/Firmware update install through windows, machine reboots and either beeps or flashes errors. HP won't acknowledge the problem, refuse to admit liabliity. Keep hold of the laptop as there will be a case against them in future. They need to be accountable for every day you can't use your machine/loss of earnings etc. If you contact them, record the call (I recorded multiple calls) and keep a log of the dates etc.
You may be able to force flash the BIOS from USB and get the machine usable, but from experience it has lost the Product ID etc, and unlike other manufacturers, they refuse to release the files to reprogram it (meaning future BIOS can't be installed etc). This is happening big time in 2022/23.
HP wake up, Apple have been made responsible at times for 10 year old macbooks. We're waiting for you HP, Make it right and between you and MS, get your act together. (Posted elsewhere in case HP will try to remove this).
由 TechPro 完成的
