跳转到主内容
加入维修社区 - 创建账户
发售于2017年11月3日。型号为 A1865, A1901。有 GSM 或者 CDMA 网络制式可选。提供64或者256GB 的存储空间。提供银色和深空灰色。(读音与“iPhone 10”相同)
I can't put a battery on my iPhone x for this reason.
hey.
this part is damaged , if i put the battery it won't fit anymore
all the stores in my area “can't fix it”
and some stores said “your problem is brand new we worked 10 years and didn't see a problem like that”
also i was searching on YouTube and didn't find anything helpful
also i can't go to apple store it will cost a lot to fix this problem too much
and i don't have a money for that so im stuck now waiting for experts like you guys.
i can replace it? because i know i can't fix it
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
@glfaisal that is your battery connector. Sounds and looks like it needs to be replaced. Any decent board repair specialist can most likely fix it by replacing the connector. It is soldered to the board so you do have to have the right tools, skills etc. to do this kind of work. Check with experts like @refectio who is in Canada. He can most likely guide you in the right direction. https://www.ifixit.com/User/1395548/Minh...
这个答案有帮助吗?
得分 2
2条评论:
thank u i will contact with him
完成的
they are not answering >> shame
完成的
添加一条评论
you will have to desolder the connector and solder a new one on its hard but not impossible
这个答案有帮助吗?
得分 1
1条评论:
maybe its an option
完成的
添加一条评论
添加你的答案
faisal 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 119
