跳转到主内容
Repair guides and support for LED, LCD, HD and other Vizio TVs.
931 个问题 查看全部
It has sound but a black screen.
I have a Vizio 70” E700i-B3. It has sound but a black screen. I’m not sure how well my torch test has been but other than some ghost-like flashes when all the lights are out in the house I don’t see anything on the screen. The Vizio support hotline said it has to be the backlight, which Vizio itself doesn’t stock, but I can’t find a part called “backlight” on part supplies sites. What are the possible causes? I see T-Con boards, power supply boards and main boards. Is there another name for a backlight? Is it the backlight if I don’t see anything on the screen with a torchlight?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论:
On closer examination, it is the backlight. I do see a faint video if flood the screen with a flashlight. So, what is really the backlight? Is there a part called "backlight"? Is it actually a light? Is it a set of strips? Is it a single board? What exactly is it and are there any instruction videos for how to replace it? I have seen videos for replacing the main board, the power supply unit and the T-Con board and they look perfectly doable. I want to know if the same thing is true of this backlight part. Thanks in advance.
完成的
添加一条评论
1个答案
r asa since you can see the background with a flashlight beam it is most likely the backlight array. (I seem to somewhat recall that there are other more sinister reasons why the back lights don’t work but can’t quite recall what the reason for that was). The backlights are strips that have LEDs on them that provide the backlight. Check the label that is glued to your LCD panel. There will be a model number listed for your panel. Use that number and do an online search for backlight strips. It’s a bit of a PITA to replace since you will have to disassemble the LCD panel but it is absolutely doable. Yours is a large panel so make sure that you keep it an a level surface and do not flex it. It is easily ruined. Also, remember that Vizio uses a hodgepodge of parts and their quality of manufacturing is at best mediocre you do want to go ahead and check that all cables are properly seated and that all the connector are still properly soldered to their respective boards. Part number for your panels backlights is most likely E700DLB003-002
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
r asa 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 60
