跳转到主内容
加入维修社区 - 创建账户
浏览一系列食品降温用电器的维修和拆卸指南。此处是电冰箱、冷柜和其他制冷设备排障和维修的指南集合。 不管您是需要处理常见问题,还是需要特定型号设备的维修步骤,此处的指南覆盖了所有可以保持电器正常使用的主题。不管是对DIY爱好者还是专业维修技师都会有所帮助。
Why is my ice maker leaking
My Kenmore refrigerator model 596.72003014 is making ice just fine. However, recently I noticed it was leaking water into one corner of the ice collection bin, which is then freezing into one big hunk of ice.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
If the ice cubes are stuck together in a row when they first fall, then the ice maker is over filling. If only a few cubes are together, your ice maker might not be level. Or, your ice maker seals are bad causing the water to leak out.
You would need to watch the the ice maker as it’s filling to determine what is causing the water to get in ice bin.
iFixit Staff Suggestion: Check out the Ice Maker Leaking wiki for other fixes.
这个答案有帮助吗?
得分 3
添加一条评论
添加你的答案
kreager1 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 47
总计 1,996
