跳转到主内容
Released in early 2015, the Canon PowerShot SX530 HS is a Wi-Fi enabled, super zoom camera. This camera weighs just under one pound. Identified by model number pc2200.
Problem with screen image through the lens
Hello, yesterday I was making the shooting, and while I was taking a picture with using the zoom, the picture on the screen through lense suddenly became very ruffle while shooting, with many bright strips, colors became distorted, an image turned into like on a very old TV with ripples. The pictures done look the same in the gallery plus when I turn on the camera I see the same effect on the screen through the lense. I was very gentle with my camera, I don’t know why It happened. Previousy the image was very clear like I look through the clear glasses. Please, If you know what to do, help me with this. Thank you in advance.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
2条评论:
Hi,
What happens if you take some pictures and download them to a computer and look at them there. Are they clear or also distorted?
完成的
@jayeff Hello, when I download them to the computer they are clear and normal
完成的
添加一条评论
1个答案
Hi,
It seems as though the camera’s LCD display either has a loose cable connection or it is faulty.
Here’s the ifixit Canon PowerShot SX530 HS Display Replacement guide.
This shows how to open the camera and check that the LCD flex cable connection to the motherboard is securely connected, (see image at Step.10). If it secure then as a DIY repair all you can do is to replace the LCD display and check if it now works OK, because if it is faulty it cannot be repaired, it has to be replaced.
Search online for Canon PowerShot SX530 HS Camera LCD Display Screen to find suppliers that suit you.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Nina Nikolayeva 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 11
总计 280
