跳转到主内容
加入维修社区 - 创建账户
Galaxy Note8 于 2017 年 8 月发布,是召回后的 Galaxy Note7 的继任者。Note8 于 2017 年 9 月正式面向公众发售。
Note8 randomly restarts when idle
I have searched all over the place for anything that works but no luck, so asking sharper minds.
My Note8 phone started refstarting randomly if left idle. The deets:
Have tried settings, updates, safe mode, cache wipes, factory resets etc multiple times. Not better even without loading backed up data and apps.
A reboot is usually every 3-10 minutes
Reboots in full; functions properly when not restarting
Can stay on as long as there is battery unless lock screen is dismissed
Stays on connected to the laptop/charger.
I concluded this may be a faulty battery as I let it run dry a few times since upgrading to a newer Note.
BUT
If I let Audible (ebook reader) or YouTube run in the background. It is a continuous operation and the phone does not restart until the app is closed. (Phone restarts with or without Audible installed so the app does not seem to be the problem).
Does it seem like the battery to anyone else, wven with the apps functioning?
Or should I reflash Samsung stock ROM. Those seem like the only options to me. Anything?
Thanks for taking the time.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
最有帮助的答案
Hi,
I don't know but was wondering if this might work as described and give you a better indication of the state of the battery.
Has the tablet been dropped or gotten wet at all?
The only other thing that I can think of is to replace the battery and check. This will at least eliminate or confirm it as the problem
这个答案有帮助吗?
得分 1
4条评论:
Battery health shows up at 83% with data from one recharge.
由完成的 分享
Hi @Aahd
You would think that 83% for a full charge would be OK, not the best but still OK, and that it shouldn't happen.
Also you said that it happens every ~10 minutes, do you know the amount of the battery charge remaining when this occurs? Just wondering if it were at <50% charge left that it might occur more frequently whereas it mightn't at >50% charge left which to me would indicate a failing battery. Maybe you can keep a check of the amount of battery charge when the tablet is on and then check again immediately after it has restarted and see if it shows nearly the same or if it is a lot different.
Also how long does a full charge last? If it is getting less all the time with normal usage, maybe another indicator for a failing battery
Not happening when on the charger and given all that you have tried it's looking like a hardware problem and at the moment the battery is the most likely reason.
As a DIY repair all you can do is to change the battery unless you can find the schematics for the systemboard somewhere. (I haven't found them, maybe you'll be luckier)
Here's the ifixit Note 8 battery replacement guide if you decide to replace it.
由完成的 分享
Thanks @jayeff for taking the time. Much appreciated.
The battery seems to hold decent charge and whether it is fully charged or low on battery, the frequency of reboots is not affected.
But yes, the battery seems to be my only option left unless anyone has another idea. I have tried re-flashing the official ROM and as soon as the downloads and updates finished and the phone was idle, it reset within minutes again.
由完成的 分享
Even I have the same issue...
Did you fix it?😊 @ Aahd
由完成的 分享
添加一条评论
Install wakelock v3 app from play store.
I fixed my note 8 which had the same problem by installing it.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Aahd 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 25
总计 1,246
