跳转到主内容
加入维修社区 - 创建账户
惠普于 2016 年 10 月发布了这款符合人体工程学的笔记本电脑(型号为 15-au123cl)。它搭载 Windows 10 操作系统并配备触摸屏。
Boot device not found
Hi,
Please I need your help. I did a Windows upgrade from 8 to 8.1 and after the upgrade I wasn't seeing wifi connections so I tried to resolve this myself. With the suggestion I got from the virtual assistant, I did a BIOS configure and saved the default settings. Now I can't boot my PC. It keeps saying Boot Device Not Found. Please what do I do?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Hi,
Start the laptop and then quickly press the Esc key followed by F10.
This should get you into the BIOS menus.
When there check if the BIOS has detected the HDD.
If the HDD is shown in BIOS I’m not sure with the BIOS in your laptop but once in there it should show which keys to operate to reset the BIOS to the default settings. Try doing that, save the changes and then restart the laptop and check if it boots OK
这个答案有帮助吗?
得分 1
9条评论:
Thank you for responding. I only saw press F9 to set default which I did. I still can't get pass the booting error
由完成的 分享
@jesseyb
Try to perform a startup repair see Method 2
由完成的 分享
Easier to press Esc. It's the magic key on HP products. That said, the key is usually F10 on the modern ones.
由完成的 分享
Finally my PC has booted. I change the boot mode from UEFI to Legacy and it worked. So what do I do next? Should I still do the startup repair? Do I need to change back to UEFI or leave it as it is now?
由完成的 分享
@jesseyb
If it boots OK and it all works OK and that you can restart it in the usual manner after you have shutdown in the usual way then it should be OK so change it back to uefi and see. If not OK when you do this you may have to do the startup repair in case something else has been corrupted
由完成的 分享
显示更多的4条评论
添加一条评论
添加你的答案
Jessey Anthony 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 4
过去 30 天: 10
总计 1,210
