跳转到主内容
加入维修社区 - 创建账户
wont turn off of sync
My iPod is locked up. the screen stays lit all the time. it wont sync to the computer. What should i do
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
4个答案
最有帮助的答案
While connecting the iPod to the computer, hold down the Shift + Ctrl keys in Windows (CMD + Option keys on a Mac). This will stop the iPod from auto sync’ing with iTunes and the iPod will appear in the source list. Wait until you are sure the iPod has mounted, and that it will not auto sync and then you can let the keys go. This may take between 3 and 25 seconds depending on your computer.
Then you can right click on the iPod icon in iTunes’ source column and select iPod Options, then check the box that says “Manually manage songs and playlists”. You can now manage your library without losing any songs on the iPod.
这个答案有帮助吗?
得分 1
添加一条评论
you should try scanning it for virus. Happened to my iPod before, it won't eject.Turns out to be the virus inside the memory is distrupting the ejection
这个答案有帮助吗?
得分 0
1条评论:
This has happened only on 5th generation iPods using PC's - Thank you PC world
完成的
添加一条评论
I got windows xp professional and can't have itunes for some reason so i went to music match jukebox and it did download some music, but now when i try to had more music while the iPod is connected it shows the new songs, but when you disconnect it they are gone, so i would like to know how can i keep new songs on my iPod, or i just need a higher windows or more advance and get only itunes for this????
这个答案有帮助吗?
得分 0
1条评论:
You need to start your own question please.
完成的
添加一条评论
I would probably make sure Im downloading them to the device and not not just using it for a Media player , or clear some of the old ones out store them on a flash drive . Make sure you have enough memory the right file system and it's completing sync.🤔🤔
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Noah 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 3
过去 30 天: 9
总计 2,703
