跳转到主内容
2.2 GHz (Turbo Boost 最高可达 3.4GHz), 2.5 GHz (Turbo Boost 最高可达 3.7GHz), 或者 2.8 GHz (Turbo Boost 最高可达 4.0GHz) 四核 Intel Core i7 处理器 ,配备 6MB 共享三级缓存。
MacBookPro 2015 Keyboard backlight connector broken
MacbookPro 2015 Keyboard backlight connector broken while dissembling the logic board ,now it was not power on , please tell keyboard has to change in order to power on.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 3
5条评论
Can you please post some pics of your cable and logic board so we can see the damage. Posting the guide picture doesn't help.
完成的
it,s broken in to two pieces
完成的
OK, still we need to see whats broken so we can guide you to what needs replacing. Do you need a new cable? Do you need a new logic board? Do you need a new keyboard?
完成的
@Dan the logic was not working already brought logic board EMC2910, from eBay ,while replacing the logic board the black light connector for keyboard was broken,it it affect the working for mac or working with broken connector.
完成的
So you ripped off the cable! Thats not the connector its self.
Sadly time for a new keyboard or uppercase
完成的
添加一条评论
2个答案
最有帮助的答案
As you damaged the keyboard cable connection to the keyboard backlight you’ll need to replace the either the keyboard backlight assembly or the uppercase which is a lot easier!
Here’s the guide to get to either 替换MacBook Pro 15‘’Retina显示器2015年中期版本的上部机身组件
New Apple Macbook Pro 15" Retina A1398 Keyboard backlight 2012-- 2015+ Screws - US
Or Macbook Pro Retina 15" A1398 2015 Uppercase with keyboard - US You’ll need to transfer your trackpad over
In either you’ll need a new battery as well! MacBook Pro 15" Retina (Mid 2015) Battery as you’ll damage yours in the process!
Replace a 8800 mAh battery compatible with a MacBook Pro 15" Retina (Mid 2015). 99 Watt Hours (Wh), 11.26 Volts (V.)图片
产品
$109.99
这个答案有帮助吗?
得分 1
添加一条评论
i crushed my connector trying to plug it back in after reassembly - has anyone been able to bend back crushed connector terminals?
这个答案有帮助吗?
得分 0
1条评论:
@owen1234321 - As easy as un-cracking a fresh egg!
Sorry guy you need to replace the damaged parts. How about posting some picks of the damage so we can aim you to whats needed 在已经存在的问题里加入图片
完成的
添加一条评论
添加你的答案
Rajeev 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 40
总计 5,000
