跳转到主内容
Google公司发布的二代Pixel XL版本,发布于2017年10月19日。配备6英寸圆角P-OLED显示屏。纯黑和黑白两种颜色及64GB或128GB存储空间可选。
20 个问题 查看全部
Requirements for phone to power on
My pixel repair isn't going according to plan, so I am troubleshooting.
1.) Can the phone power up without the shield above the logic board? Also, what about the screws. Do they serve any conductive/grounding purpose?
2.) Can the phone power up with no display?
3.) Can the phone power up with no battery? (I.e, USB cable only, and battery disconnected?)
4.) What components can the phone function without? (I.e, if I had to do a trial/error teardown, are any components essential to the phone powering up?)
5.) The logic board seems to have multimeter contact points. Can this be used for proper testing? (I have a multimeter)
Thank you in advance!!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
I have not worked on a google pixel before but here’s what I found out from working on other phones:
  1. That shield probably doesn’t do anything, and I haven’t seen a screw that is conductive, I doubt the pixel has one
  2. Yes, but you won’t be able to see anything
  3. Usually phones boot loop if you don’t have a battery connected
  4. Logic board, battery, charging board (you could use the power button instead, although I did this on an iPhone 11 and it wouldn’t turn on)
  5. I have no idea, I have never used a multimeter
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Logic Islife 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 299
