Will Not Boot Into Leopard After Permissions Fix
Recently, I decided to do a little modification to some of the visual aspects of mac os x, and unfortionatly couldn't access the CoreServices folder, even as a Admin(though I never got around to modifying any files). I did some Googling, and found a way to change the permissions in Leopard (Since everything I have read says that Leopard has a lot of permission issues) I set it so that Myself, and Admin could read, and wright. After i did this, I rebooted the computer, and it seemed fine, it showed the apple logo, but never showed the spinning progress wheel.
I then tried booting into Ubuntu (which is on a different drive then Leopard) and it worked fine, and I could access the disk from ubuntu. I then tried to boot into Panther (Which is on annother drive), and that also worked fine. In panther, I used disk utility, and Used the "Verify Disk Permissions" option, and it gave me a bunch of permissions that needed to be repaired, so i told it to do that (and it took about 3 Hours) After that I also used the "Verify Disk" option, and it said "Block Count Invalid" so I repaired that, and it told me that the repair was successful (I actually did this before the permissions verify, i think).
After that was done, i rebooted the computer, and was relieved to see the progress well spining as the computer began to boot into leopard, unfortionatly, after the progress wheel spun for about 25 Seconds (The ususual boot time for this machine) it went to a black screen, as if it was logging into Mac OS, and then the computer chimed, and rebooted.
So the issue still remains. After booting into panther again, i checked the disk, and all of my files were still there, but that disk had a lot of disk images (For Backup over 10GB of older drives i used to own, and I cannot copy these onto my external hard drive since when i bought it and first set it up, I forgot to re-format it in NTFS, and now it uses the FAT filesystem so no files over 4GB, and it has more space used than any other drive I own) so I cannot wipe the drive. In panther, i can acess the disk, but the computer can't boot off of it.
Here are some pictures of the Babble in verbose mode, and it looks as if it's trying to boot an Intel Mac.
Any Ideas?
Thanks,
Chris
2条评论
Do you have TechTools Pro? http://www.micromat.com/
由 mayer 完成的 分享
I'll try that, if this helps, in Verbose Mode, I see a lot of babble about being unable to allocate class "AppleIntelCPUManagement" and alot of babble about problems with that, which is odd since it's a G4
由 Chris Green 完成的 分享
