跳转到主内容
Black and silver single cup coffee maker with water reservoir on the left hand side. K40/K45.
98 个问题 查看全部
How to make it brew Proper Cup size
I have a Keurig K-Elite, it does not look like the picture, but this is the model I have (https://www.amazon.com/Keurig-K-Elite-St...) and no matter what, I can not get it to brew over 8 oz.
The K Elite has five cup sizes, the 10 oz, and 12 oz will only ever brew 8 oz.
I have cleaned descaled, done all kinds of things to fix it.
I wonder is there is a part that I could replace like the air pump that would fix this, or is it a circuit board problem.
Is there a way to diagnose exactly what failed inside the keurig?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
2条评论:
this is 2023 and i have the same problem. at least keurig is consistent. HAHA
完成的
@syfgqtlv63fo3uq check on my answer on here Cup is not getting full This can definitely cause the low amount of water.
No.More.Keurig.
完成的
添加一条评论
2个答案
Are you sure you fill the reservoir to the proper amount for the task?
这个答案有帮助吗?
得分 0
1条评论:
Yeah, It has a 75 oz reservoir tank, that I fill up.
完成的
添加一条评论
@laurenwatson just to answer for clarification sake. I'd start looking for common obstruction in the water flow. This seems to be an issue with the Keurig Single Serve Coffeemaker Brewing System. After a while it appears as if scale build-up or other contaminants prevent the Keurig from brewing full 12oz. It takes longer to brew, the Keurig becomes louder and it dispense on the average 4oz or less. This is a "quick and dirty" guide
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
LaurenWatson 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 16
过去 30 天: 42
总计 217
