跳转到主内容
加入维修社区 - 创建账户
Google 第三代 Pixel 系列智能手机,也是其首款“刘海屏”手机。配备 6.3 英寸 QHD+ OLED 显示屏,提供 64 GB 或 128 GB 存储空间。有“纯粹白”、“只需黑”或“非常粉”三种颜色可选。
Black Screen after Display Replacement
Hello, This google Pixel 3XL I have had a damaged lcd but the screen was still visible it was just cracked. I went to do the screen replacement and everything came off fine and there is no visible damage, but after replacing the screen the display is black but the phone is powering on, so i assumed that the new display I had received was defective, but i put on a second screen today and it is having the same issue. Any help would be greatly appreciated trying to get this running asap. Thanks.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
2个答案
已选择的解决方案
It appears that the display would not come on completely until the back cover of the phone was put into place and the capacitive pins on the touch ID sensor were making contact, very strange issue, but once all together the problem was resolved, and the display came back on phone appears to be working fine.
这个答案有帮助吗?
得分 0
添加一条评论
最有帮助的答案
Did you disconnect the battery before you removed the screen? .you could have damaged the back light circuit. Look and see if you can see anything is a darker room and shine a light on the screen. And see if you can see anything.
Update (06/11/2020)
It sounds like you might have blown a filter on the back light circuit. You should pull the board out and check the circuit. Or if this is out of you skills take it to a repair shop. You will most likely need do microsolder work.
这个答案有帮助吗?
得分 1
4条评论:
The battery was disconnected before the screen was removed. I have shined a light on the screen and cant seem to see anything. It appears that there is no backlight, the screen seems to not be powering on at all but the phone is vibrating and notifications sounds are coming through.
由完成的
Update: It looks like once i had the back panel re connected with the touch id touching the capacitive pins then it brought the display on, not really sure as to why this would work but it did. Thanks for your comments, and I am a repair shop and it doesn't appear any microsolder work is needed.
由完成的
Ok. I didn't know what your skill level was. Glad you figured it out.
由完成的
Yeah it's not problem haha thanks for all the suggestions it helped me work through the problem.
由完成的
添加一条评论
添加你的答案
Matthew Clark 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 14
过去 30 天: 27
总计 3,246
