Why is my car not firing?
I have changed the plugs and wires and still no fire to them. What all can I check to fix this problem?
Check your crank sensor. It is the crank sensor that sends a signal to the PCM, this signal determines when the PCM fires the coil. So I would check crank sensor then PCM for spark. You can download the ignition part from the service manual right here good luck and I hope this will work for you.
这个答案有帮助吗?
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 4
总计 1,251
1条评论
Of course the engine turns over, and there's a spark from the coil wire?
由 originalmachead 完成的
