跳转到主内容
The first generation Neon was introduced in January 1994 and manufactured until August 1999. It was available as a four-door notchback sedan and a two-door notchback coupe.
29 个问题 查看全部
Why is my car not firing?
I have changed the plugs and wires and still no fire to them. What all can I check to fix this problem?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
1条评论
Of course the engine turns over, and there's a spark from the coil wire?
完成的
添加一条评论
1个答案
已选择的解决方案
Check your crank sensor. It is the crank sensor that sends a signal to the PCM, this signal determines when the PCM fires the coil. So I would check crank sensor then PCM for spark. You can download the ignition part from the service manual right here good luck and I hope this will work for you.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
jamey 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 1,245
