跳转到主内容
The Nokia 6030 is a GSM dual band handset with automatic switching between frequencies.
How to repair power button?
The Nokia 6030 has its power button on its top as part of the back casing.
I have noticed that the button does seem to work/respond very well anymore on a unit. My impression is that its alignment with the contact it presses into may not be correct. Perhaps the button is somewhat warped.
It looks like the button may be removable, but I have not been able to remove the button with decent pressure from under where it appears to be attached.
How can one repair the power button? Can the repair be done without replacement of the back casing itself?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Nokia 6030c-2 many bottom not working problem
这个答案有帮助吗?
得分 0
1条评论:
Nokia mobile 6030c-2 many boton not working problem
完成的
添加一条评论
添加你的答案
User5 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 116
