跳转到主内容
加入维修社区 - 创建账户
Model A1225 / Mid 2007 and Early 2008 / 2.4, 2.8, or 3.06 GHz Core 2 Duo processor
Top backlight doesn't turn on
Hi,
my 2008 iMac 24” have this problem. The top of the screen turn on with very few brightness, very very low. The bottom work perfectly. On internet this problem is called “backlight” and I really need to find a solution. Please help me. Thanks a lot
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
Thanks a lot both @oldturkey03 and @Nick. I'll try to follow your advice
完成的
添加一条评论
2个答案
已选择的解决方案
@weenico this appears to be a backlight issue. There should be 7 backlight CCFL tubes for your LCD screen so the top one may have gone bad or it is the inverter that is failing. Most likely it will be the CCFL. You will have to take your iMac apart and take the display assembly apart. The CCFL should be accessible from the side of the display. CCFL’s are becoming hard to find so you may have to scour around to find it. Some companies offer CCFL-LED conversion kits  etc.
这个答案有帮助吗?
得分 0
添加一条评论
The first thing I would do on one of these is try the inverter and try my luck - you may get lucky, but as @oldturkey03 said many of these are at a point where the CCFL tubes are worn out and burned out due to high resistance after having thousands of hours put on them. The issue with these displays today is many of them are 10+ years old, and they’re beginning to show their age by having early failure warnings or burning out entirely, so I would do so with the full understanding it may be due to the screen.
If it’s due to a bad screen, I would try the LED conversion - finding good compatible CCFL tubes is nearly impossible today, and you need to do all of them as a set since they need to have similar resistance or it will accelerate the wear on the rest of them.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Niccolò Errico 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 6
总计 123
