跳转到主内容
加入维修社区 - 创建账户
Canon PowerShot A590 IS 是一款 800 万像素数码傻瓜相机,配备 4 倍光学变焦和 2.5 英寸液晶显示屏。
New LCD In Place, but won't work
LDC is white with no image ! It has a pink small circle in lower left corner ! Any suggestions !
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
已选择的解决方案
open it back up and recheck your connection for the LCD. remove battery first. it may be that you haven't connected fully or you have some dirt/fingergrease on the pins, give it a wipe over with electronics cleaner or isopropyl alcohol if you have it.
这个答案有帮助吗?
得分 2
1条评论:
My first guess is that the pink circle is on a protective film/sheet of plastic from the factory to keep the polarizing film on the LCD from getting scratched before it is installed. You should remove that. You can normally catch it at a corner with a finger nail. Next, the ribbon cable is either not seated square in the connector, far enough in, is curved/bent where it goes into the connector, the end is dirty or the ribbon cable is defective. Sometimes those look like they are in there right but are just a frogs hair off and won't work right. Polly is giving you good advice.
完成的
添加一条评论
添加你的答案
Marvin Sanders 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 12
总计 765
