跳转到主内容
苹果官方于2015年9月25日正式发售iPhone6S A1688/A1633机型。 此机型的修理方式与先前几代差不多, 需要螺丝起子及撬棍工具。 同时也适用GSM or CDMA/16, 64 or 128 GB/ 银色, 金色, 深空灰色, 玫瑰金色等机型。
iPhone will not power on and is not recognized by PC
My iPhone powered off suddenly while I was using the hotspot. The battery was not low when it powered off. Now it will not power on and is not recognized by my PC when plugged in with an OEM Lightning cable. I opened the phone and disconnected the battery, waited at least 10 seconds, then reconnected the battery and attempted to power on again. I tried this several times with no luck. I’m thinking that the battery needs to be replaced, but wanted to see what you guys think first.
Thanks!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
@bomtomdabil yup, start with a new battery and then re-evaluate to see what is going on. If nothing else a new battery will give you a known-well starting point for further troubleshooting. iPhone 6s 电池更换
Hopefully you were not using non-original chargers/cables since those are known to destroy the charging circuitry on the logic board. Charging issues as well as non-booting issues can be related to the Tristar IC (U4500) which is all part of it. Again, start with a new battery and see what you get.
这个答案有帮助吗?
得分 2
2条评论:
@oldturkey03 Thanks for your response. I just did a battery swap with a family member's iPhone 6S+ with the same results. It has, unfortunately, been used with non-original cables. Is there a way to quickly see if they have caused the problem, or would I need to replace the entire logic board to find out?
完成的
@bomtomdabil I figured something like that. I got a bunch with the same issues laying around. You can get a tristar tester like this ($$$) and check it out. Or, of course you can contact reputable sources like @refectio to see if he can help you out.
完成的
添加一条评论
添加你的答案
Bom Tomdabil 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 56
