跳转到主内容
加入维修社区 - 创建账户
型号 A1286。2011 年 2 月发布 / 2.0、2.2 或 2.3 GHz 四核 Intel Core i7 处理器
I can change the cpu?
I can change the serial i5?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Sorry the chip its self is not socketed as such you can’t replace it.
But! What you can do is swap out the logic board with a better CPU. This series also has a known issue with the dedicated GPU I would recommend you look at installing a 2012 logic board to get both a better CPU but also a better GPU!
The board is a direct drop in with just one minor alteration needed in the LVDS cable as the newer board has a slightly different connector. All you need to do is use a nail file to file down the cable connectors tang ever so slightly on both sides.
Here’s the logic board info for the 2012 boards
  • 661-6491 - 15” Macbook Pro 2.3GHz i7
  • 661-6492 - 15” Macbook Pro 2.6GHz i7
  • 661-6493 - 15” Macbook Pro 2.7GHz i7
Here’s one source for the part 15” Macbook Pro 2.6GHz i7 Logic board
And here’s the guide to put it in MacBook Pro 15" Unibody 2011早期 逻辑板更换
这个答案有帮助吗?
得分 3
添加一条评论
添加你的答案
Pipe Lol 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 13
总计 273
