Logitech 510 Mouse does not transmit to computer.
The mouse does not transmit to the computer and the “invisable optic” light does not light up.
Try a new battery and check the connections on the battery and make sure the battery is facing the correct direction.
这个答案有帮助吗?
I tried that--problem is that the LED on the bottom does not light up, and I disassembled the mouse, inspected it, and can not find any obvious issues.
Thanks
Anything else you can suggest?
My guess is you need a new mouse. If none of that fixes it.
One could try re-pairing to the dongle through the Logitech Unifying Software.
And the “invisible” optic should be indeed invisible.
这个答案有帮助吗?
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 8
总计 629
